JnJnKatiebug's avatar
JnJnKatiebug
What's up with the fridge?
I posted a question here about changing out to a residential fridge and running it off an inverter while traveling. My fridge is over 13 years old and would not cool below 42 degrees. We ran it on electric most of the time because the burner would make a popping noise when it was on gas. Well, as a last ditch effort, Wednesday I took it to a local repair shop and had the burner replaced. I figured it was just throwing away $200 bucks. Picked it up Wednesday night and took it home with the fridge running. It is sitting in my driveway in full sun, 95 degrees outside. When I got home yesterday afternoon I went in to check the temp. Wow, 32 degrees inside the fridge. Should I dare hope that was the problem. I am thinking now that maybe the heating element on the electric side is not working correctly as well, thus new burner = better heat. You can barely hear the new burner, the old one was very loud. The tech also ask who did my recall. He said the wiring was just threw in there "willy nilly" (his term). He said he redid the wiring for the recall and did it like it was supposed to be. DW and I were talking last night, the fridge really has not worked properly since we had the recall completed. Mayby the tech that did the recall did not hook the fans back up. Maybe something there, who knows. We are heading out tonight for four days on the river in MO. I have my fingers crossed.
  • The recall if you have to wire the recall thru the main control board, will sometimes be done WRONG. There are 2 wires connected to the center of the control board after the black cover is installed. Those are the Rear Fan control wires. They are Whit and Black. IF they are reversed, the ONLY problem that will cause is---the rear cooling fans will not come on. If those fans are not operating the 1200 will NOT get cold enough. There is NO way to miswire the recall kit itself. Just inexperienced people that do not know where wiring goes after they do a shoddy repair. The 2- 120 elements. They either WORK or they do NOT. There is no partial operation of a refer 120 element. The problem you had was the rear fans were not operating until the good Tech found and fixed the problem. Doug
