naturist wrote:
Um, wait a minute, when you plug your shore power cord into the 300 watt inverter, you are also plugging in your RV's converter, which, if it thinks your house battery needs charging, will attempt to do so. Most RV converters draw something like 600 watts or more in the beginning stages of charging a battery, which would overload and shut down a 300 watt inverter. If your house battery were fully charged, this would not happen, but if it is down a bit, it would, accounting for the intermittant nature of the problem.
Yes but read my original post.  Breaker for converter is OFF anytime I use the inverter.
