TeryT wrote:
Trackrig wrote:
An accumulator tank will help with the noise by preventing the pump from kicking on as often. I installed a large one in the the same compartment as the water pump in the DP, very little plumbing to mess with that way. I'm having problems with where to install a large one in the 26' TT, may have to go to one of the small ones.
Bill
Many of the pumps I've looked at say NOT to use an accumulator. And the space is really tight, so not sure where I would even put one . . . but you're saying it will help with cut-on frequency, not with noise, right?
You do not want to use an accumulator with a bypass of variable speed pump. It will circumvent the way the pump is designed to work and it will actually run more. An accumulator tank is great for the standard, single speed, non-bypass pump though, like the shurflow 3 GPM pumps so many RV's come with.
