Upon return from the last trip or two, I have found a couple of the wheels have had the dust caps fall off (the cap, with the rubber nipple which covers the hub opening). Found them loose inside the h...
Are you talking silicone in a couple spots on the outside, spanning the joint between the cap and hub, or under the cap, between the two surfaces? And, will any silicone stand up to any heat generated by rotation/braking?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
