Denny & Jami wrote:
Bill.Satellite wrote:
If you have BOTH an exterior satellite connection and a cable connection then we are talking about 2 different things. Most RV's only have one outside connection which is designed only for the use of a campground cable connection. These cannot be used to connect to satellite unless the connection is modified and many can be successfully modified with the use of an additional cable and an A/B switch. I have done it hundreds of times.
Maybe with a standard dish but not a Tailgater.
Denny
Are you speaking from experience? I am. I agree that the cable connection, unmodified will not work with the tailgater or a standard dish. I use the cable connection (modified) per Bill with an A/B switch with my tailgater and it works fine. Anyone who has not been able to get it to work hasn't got the modification done right. I have the PDF on my computer. If anyone is interested PM me and I will e-mail it to you.
