DrewE
Apr 26, 2020Explorer III
The GFCI probably isn't liking the modified sine wave output of the inverter.
A GFCI does not need bonded ground and neutral at the input. In fact, using a GFCI is the only way I know of that the electric code permits installing a three prong outlet on an existing ungrounded circuit in an old building (that is, without running a ground wire and making it a grounded circuit). A GFCI will trip if ground and neutral are connected together somehow downstream from it.
