Flute_Man
Apr 27, 2020Explorer
pcottrell81 wrote:Flute Man wrote:
GFCI‘’s trip because of a grounding issue. Please make sure nowhere in your RV that you’re neutral touches the ground. Within the RV Neutrals and grounds must be isolated from each other. You may call me if you wish.
I am going to replace the inverter its definitely the culprit.
Unfortunately, my electronics deserve a better inverter anyways so they shall receive it haha.
I have had a modified sine wave 2000 W inverter for 16 years and everything plays very well with it. Never had any problems.
I have been a professional high-tech troubleshooter all my life. I would rather find the real problem rather than throw money and parts without doing a proper diagnosis. I certainly wouldn’t let my doctor t Do such thing. There has been a lot of good suggestions about the grounding aspect. If it was me I would do all those suggestions first. Like I said before you may call me. I can help you over the phone. I’ve done it before with good results.
Jerry Parr
602-321-8141
Arizona
