dougrainer
Jun 29, 2013Nomad
Carvin Marvin wrote:
Thanks Doug. Is the tstat visable or does the refer have to be pulled for access? Marv
If NOT in a slide room you have to pull the refer. VERY common for the tstat to fail after a few years. If you pull and replace, REPLACE the 2 fans also. Also, run 2 wires from the tstat down the back to the rear refer area. That way you can run the fans at will which will make the refer more efficient and IF the tstat ever fails in the future, you can bypass with those 2 wires to run the fans and even test to make sure it is the tstat and not the fans. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
