myredracer
Mar 12, 2014Explorer II
x2 on the caps. Sounds like a faulty start cap.
Some info. here. RV AC capacitors As mentioned, if you are going to take a cap. out, short it out first to discharge it. If you can't test a cap., I would just go and replace one first and see if that fixes it. If not, re-install it in the other AC. Or spend the extra $20 or so and just replace it in both AC units. I guess it's also possible to be a faulty start relay but more likely a cap.
You won't be able to measure the actual startup current with a multi-meter. It actually goes as high as around 6 times the run current for a small fraction of a second and it won't show on your meter. You can find the starting current in a AC manufacturers tech. data.
Some info. and pricing on Coleman caps.: Coleman AC parts Maybe you have another make though.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
