time_to_go_now's avatar
Mar 11, 2014
When the back A/C starts, the genny dies!
Onan 6000 quiet diesel with 1,600 hours. Used to be able to run both 13.5 A/C's with no problem. Now, with the front A/C running, and then start the back A/C unit, the genny dies. Flashes code 22 which is overload condition. No breakers blow. And the genny will restart right away.
I measured the A/C load at start up at 18 amps and at 8 amps while running. Both A/C's pull the same load. Both a/c's run fine off a 50 amp plug in.
I think the genny THINKS there is a overload condition, but I don't really think there is one. I think some sensor went bad. Had the genny checked out by Onan technician. It was given a clean bill of health.
I'm not so sure.
Any ideas???
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
