IAMICHABOD
Sep 08, 2019Explorer III
Old-Biscuit wrote:
Off level operation...even for as little as 15 minutes....causes overheating
Overheating causes the sodium chromate to crystalize and plate out.
Plating out causes obstructions which inhibits coolant flow which causes more overheating ---repeat the damage cycles over and over and over
Off level damage is accumulative and PERMANENT (crystals do NOT go back into solution)
Old fridges, new fridges....doesn't matter.
Process is the same.
ARP real time monitoring shows just how quickly the boiler temp WILL increase due to off level operation.
Plain and simple. It happens and it causes damage.
If treated properly what is the life expectancy of a fridge ?
