JayMartin
Aug 21, 2014Explorer
enblethen wrote:
Can you give a discription of what it does or doesn't do?
The main switch controls nearly every function.
Have you used some aersol air on the switch?
Have you cleaned the stack and the burner area?
Any signs of yellowish powder in the outside access?
It does absolutely nothing. When plugged into shore power, I turn the main switch to AC and the temp switch to max. The green/white meter beside the main switch doesn't budge. I will do what you suggest above and let you know what I find.
Thanks,
Jay
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
