opnspaces
Aug 13, 2023Navigator III
Hi Mike,
Where or how are you seeing 328 amps? That sounds excessive.
The charge controller is typically in the same housing as all the fuses and breakers. You might have to pull the from of the fuse panel off to look. Make sure you take a picture of the fuses before you start removing fuses so you can put them back where they belong when finished.
