Cptnvideo
Aug 18, 2023Nomad
USMarine0369 wrote:Cptnvideo wrote:
The original converter (now unplugged) in my Solitude is located in a dead space behind the pass thru compartment, right next to the transfer switch. A panel in the pass thru has to be removed to access.
So your converter is unplugged because you have a new one that replaced it? Or does the battery charger plug into the inverter?
Thanks,
I have an inverter/charger and a solar controller. The charger portion of the inverter/charger is almost always turned off since the solar controller normally supplies enough amps to keep the batteries charged.
