CA_Traveler
Aug 19, 2023Explorer III
USMarine0369 wrote:To measure the AC input amps clamp on the hot wire. There may not be a wire available for a charger that is integrated into the main CB panel for example. Clamp on the charger DC positive wire to measure the charger output amps.
Thanks. So what cables would I clamp (I have one of these voltmeters)?
For the battery use either the + or - cable to determine battery amps, ie either charging or discharging amps. If there are multiple wires on the battery post then measure each one and sum (each one may be + or - amps).
