- Chris_BryantExplorer IIThey publish a bunch of diagrams online- the website has changed, but https://winnebagoind.com/product-resources/product-information gives a drill down menu, with all parts and wiring daigrams- wiring very good, as Winnie uses marked wires.
I see a reason it has changed- they now have manuals online back to 1969.
Respect. - BobboExplorer IIIContact Winnebago. I bet one of the online wiring diagrams is the same.
- K_CharlesExplorerWinnebago has more wiring diagrams on line then you could read in a lifetime but it looks like you are right, not the chalet. I don't know where else you could look.
- GdetrailerExplorer IIIWiring diagrams for MOST RVs are typically NOT EVER "released" to the general public.
If you must have it you MUST contact the manufacturer DIRECTLY and even then I highly doubt you will get them..
What is it you are trying to troubleshoot that you need the wiring diagrams?
Most RVs are dirt simple, you have a power distribution box which one half contains 120V stuff and the other half contains all the 12V stuff.. 120V side uses breakers and 12V side uses auto fuses..
Typically the power distribution box will have a 12V power supply tucked into the bottom of the box (AKA the "converter").. That takes 120V AC and outputs "12V" which supplies all of your lighting, furnace power and other 12V items along with recharging the battery..
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
