joeburnes
Jun 13, 2017Explorer
So would you install the inverter behind the fridge and use the 12v wire that already exists? And then I assume you would use the outside access panel to unplug the fridge from the "wall" and plug it into the inverter whenever necessary?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
