MrWizard
Jun 13, 2017Moderator
No
You install the inverter close too the batteries
And run a new circuit for the 120v to the fridge
The existing 12v wiring is to small for the inverter
The 100+ running Watts , a small 1 amp at 120v is a small easy load of 10 amps 12v into the inverter
It's the 900 Watts compressor start up surge, that means you can't use the existing wiring
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
