Gerald55's avatar
Gerald55
Where to buy crimped battery cable
I'm looking to finish a DYI inverter install and want to buy battery wire in fat gauges around 0, crimped. I want to keep all the runs as short as possible so want to specify an exact length, like 14 inches, rather than just getting a stock 2 foot cable.
I'm in a big city (San Diego) - where can I look for such a thing? The auto parts store didn't do it.
BTW, after I pulled off the 4 AWG cables off my batteries as part of the install, I pulled on each of the crimps and found most of them loose, with perhaps 2-3mm of give, in the direction of the wire (i.e., you pull and it clicks forward 3mm, and then you can push it back 3mm also). Is that normal, or indicative of a bad crimp?
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 22, 2025
