2oldman
Mar 04, 2015Explorer II
BurbMan wrote:2. Possible. How many lineal feet you doing?
2. Buy this seal and trim it.
3. Install as is, maybe it will "sweep" better if it's longer?
3. Hard to say. I did my big 5er slide last summer. The new seal seemed to be a lot stiffer rubber than the old worn out seal. I can tell the slider motor is working harder to move the slide, and it's real noisy.
It took me awhile to get things to fit right - I wouldn't say this is the easiest DIY I've ever done. I had to spot-trim it in places where it was binding. Some of my trimmings are obvious to the eye - kinda ragged, and in many places water is not being wiped off because the stiffness forced me to have the blade tip just touching the slide surface. And that's tricky.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
