Gdetrailer
Nov 18, 2013Explorer III
marinemommy wrote:
Hi all,, we have a 1993 Layton 19foot fifth wheel that we'd like to keep on the road as long as possible. The entry door is literally falling apart. Anyone know of anyplace in either Northern Ca, or Northern NV area that might sell used parts? Don't really want to put the expense of new door, if we can find used. Thanks so much!!
RV doors tend to be made specifically for the RV manufacturer for that particular model. This makes RV doors that fit your application a bit difficult to locate.
With a little effort and a few hand tools you can often disassemble a RV door and either make a new wooden frame or just replace the bad wood.
My trailer I opted to make new doors from scratch.
Typically the framework is made from 1x2s, foam insulation fits in between the frame and the inside and outside panels are glued to the wood and insulation. Hardest part often is getting the panels separated from the glue without damaging it. But if the door has been water damaged enough it most likely will not be all that hard (my old door was easy to pull the panels off).
On edit.. Nuts, google has swallowed my documment, it is no longer viewable..:M
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
