LaytonLad
Oct 07, 2013Explorer
Restoring 1965 Skyline Layton
Hello,
I've heard some great things about the community so I thought I would start here and check it out. My name is Ray and I recently purchased a 1965 Skyline Layton 12ft trailer. My first attempt at restoring a trailer. I am thrilled to have a project that I hope will allow me to be able to make weekend runs to the beach. I have several questions that I am hoping you guys wouldn't mind helping me out with.
Below I included some pictures of the trailer. Please correct me if I am wrong with any of my information. The bottom wood is rotten and will need to be replaced. I want to completely remodel/restore the trailer.I want to cut the weight as much as possible by using Aluminum studs or even galvanized steel studs. I am 75% sure I will go with the aluminum studs. The prices are with in the same amount as using regular wood studs. I am fairly confident the aluminum or steel frame will be sound enough to hit the open road without it being blow apart.
My plan of attack is to remove the siding, take a picture of the frame, labeling then measuring each piece. After building the metal frame in 5 or 6 sections, front, left, right, ceiling, floor and back I would then remove the wooden frame and replace one side at the same time with the aluminum frame. I realize teh floor will need to be plywood. I planned on measuring the wood that is currently in the trailer.
I want to add a solar panel to be able to run a AC, TV and hot water heater. From a small amount of research on that item it seems affordable and feasible at the same time.
The water containers cap seems to be super glued on. I tried everything short of dynamite to open the cap but I've had no luck. I can hear what sounds like rust or sand moving inside. While trying to focus on the lighter side I want to replace it with a water bag or maybe a plastic, pvc, container.
If anyone would be willing to point me in the right direction or confirm what I am thinking it sure would mean alott. A little assurance goes a long way. I am 100% open to all suggestions so please feel free to correct away. I thank you in advance and look forward to meeting those in the community I can.
