JRRNeiklot's avatar
JRRNeiklot
Where to put shunt
I need to install the shunt for my battery monitor. Batteries are wired to the inverter already. Is it necessary to put the shunt directly next to the battery bank or can I put it inline between the charge controller and the inverter? Using the CC wiring will necessitate 6 guage wire as opposed to 1/0.
Thanks for all advice.
  • BFL13 wrote:
    Please say what monitor the shunt is for. A battery monitor like the Trimetric takes all the neg wires to its shunt and then just one fat wire to the battery neg post.
    A solar monitor only monitors the solar so it's shunt is upstream of the Trimetric
    Trimetric 2030-RV
  • Keep shunts, buss bars, fuses and breakers as far away from a flooded battery as possible. A proper hookup will have one single solitary cable connecting the positive post and one single solitary cable connecting the negative post. Of course battery paralleling bridge wires are not counted.
    The shunt's milliamp wire terminals should be soldered. The contact point to the shunt's metal should be mirror bright then a coating of NON PETROLEUM BASED sealer applied over-top. I am so fussy about shunt connections I solder the wires direct to the shunt metal.
    I picked up a lab grade Manganin shunt on eBay. Before the internet here took a dump. I would love to find a 4-1/2 digit 100 mv 100-amp meter, but where? I can't even search for one. Grrrr...
  • Please say what monitor the shunt is for. A battery monitor like the Trimetric takes all the neg wires to its shunt and then just one fat wire to the battery neg post.
