TPTCDT's avatar
TPTCDT
Which Fuse?
Anyone know which fuse # powers the driver door mirror control, window up/dn and heated mirror?    It doesn't specify in the manual.  Thank you...
Year:     2007
Make:    Winnebago
Model:   Voyage 38J
Frame:  Workhorse Voyage W24
  • Thanks for coming back and updating us on the repair. You would think they would put things like relays in a more accessible location.
  • I found the circuit breaker under the dash, it was fine.  After lengthy study of the schematics I found a relay in common with all 3 of the faulty devices (window control, mirror adjust and mirror heater).  I finally found the relay under the dash cover behind the speedometer.  Tested and the relay was bad.  Replaced and good as new.  Replaced the other 2 relays there as well to avoid future problems.  Take care....
  • Try looking inside the fuse box cover. There is usually a chart showing each fuse location and their function.
