BFL13 wrote:
You can get the inverter to not alarm off until at a lower SOC by using shorter/fatter wires between it and the battery bank.
I see a 0.8v drop while running a load that pulls 90 amps from the battery bank of four wet 6s.  This means I can be at 12.2v to start and it will stay above the 11.0v alarm point.  (Allows for the initial drop to 11.4 and then some for decline while load is running)
Ah - I have my alarm set at 11.9. The 90 or so amps my pot pulls causes a .5V drop with AGMs. Can I really run the volts that low without damaging anything?
