Canadian_Rainbi
Sep 22, 2013Explorer
pianotuna wrote:
Hi,
The answer partly depends on the intended use. If you wish to use a large inverter (1500 watts and up) the 12 volt solution, wired in a balanced manner may outperform twin six volt jars.
The 12 volts MUST be wired in a balanced manner for them to work in an optimal manner.
Here is a simple flow chart.
Budget-->Energy Audit-->Battery bank size-->number of watts-->PWM or MPPT.
Here is a link to the rather special spreadsheet that N8GS has created to help size solar battery charging systems!
Solar Spread Sheet N8GS
I do recommend between 60 and 150 watts of panels per 100 amp-hours of storage.
Here are two sites worth reading:
http://rvroadtrip.us/library/12v_system.php
http://rvroadtrip.us/library/solar_install.php
Well I was close Don! I shouldn't post late at night! :S
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
