ktmrfs
Sep 23, 2013Explorer III
pianotuna wrote:
Hi BFL13,
Under heavy loads use all the batteries. It is possible to bank switch, as I isolate my two banks. Charge them separately, or even charge one bank while using the other. This is especially nice when there is some solar energy to be had.
The only potentially safe way to use the heater exhaust that I can think of, is to have double walled tubing acting as an additional heat exchanger/extension exhaust pipe. Possible but pricy.
how about this "out of the box" idea to keep batteries warm. run a pipe from the hot water heater through the battery compartment to warm the batteries. cover the battery boxes with foam insulation to retain heat. if done right it should thermosiphon so you don't need the water pump to circulate the water. Use more propane, but for us that wouldn't be an issue.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
