tplife
Sep 23, 2013Explorer
pianotuna wrote:
Hi,
That is unwise advice. AGM's do fail and can create poisonous fumes when they do. It is prudent to have them in a sealed container which is vented to the great outdoors.tplife wrote:
BFL13, AGM batteries don't have to be outside and don't have to be vented, so having them "warm" inside is a non-issue as well.
The only way that can happen is if you purposely short an AGM and overload it, and it's dirt cheap to prevent shorts using fuses - I double fused my own application. I get the impression from your comments that you aren't familiar with AGM batteries at all. They don't need or require containers or venting and are rated for use safely inside any enclosure - even mounted upside down. That's why they're used exclusively in aviation and why they are the best choice for applications inside occupied enclosures.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
