jrnymn7
May 01, 2015Explorer
Ignoring Vmp vs. Voc, etc. (use whatever numbers you like, the results will be similar):
97w is about 3X 32w, however, it is amps into the bank that really matter.
Using mppt/series, set at say 14.6Vabs... 32w/14.6v = ~2.2a going into bank
Using pwm/parallel, set at 14.6Vabs... 4.47 x 20% = ~0.9a + 4.47a = ~ 5.4a, so about 2 1/2 X as much.
Using mppt/parallel, set at 14.6Vabs... 97w/14.6v = ~6.6a, about 3X as much.
Of course, the diode issue could change all that, but parallel appears to have it, hands down.
