Almot
May 01, 2015Explorer III
Jrnymn7 - besides inability to add a remote display (so that controller could be tucked away where you don't see it or where it's closer to batts), Solar 30 is a "semi-manual" kind of a controller. Like a regulated DC-DC converter. You have to change the voltage manually every time to go from Absorb to Float and back. Or set a voltage somewhere in between Abs and Float, so it would be lower than recommended Abs and higher than recommended Float.
It's hard to find a good PWM in 30A range. Probably because at this level people already start thinking of 24V panels, shading or not.
