Ivylog
Nov 10, 2014Explorer III
My heat pumps do NOT switch to my AquaHot at any temp which may explain why they keep working when it 's below freezing. Home units can be adjusted to do the same but if you select a temp more than four degrees warmer than the current temp many will switch to the emergency heat which is usually resistive heat.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 19, 2026
