BFL13
May 16, 2015Explorer II
Pirate wrote:
I two rather huge deep cycle wet type batteries. They are about 20 feet from the converter location. The existing converter looks like a parallax 30 amp unit. I never charge using my generator. I'm either driving or plugged in. No boondocking.
You don't need a new converter if you never boondock.
The Parallax unit you have is a 30 amp (AC--120v) unit that may do say 55 amps at 13.8v DC. If you are on shore power forever, that is all you ever need forever.
For that scenario, you should have only one 12v battery and replace it every couple years or so. If you have more battery bank than that, it will need a charger that can go into the 14s and even the 15 volt range at times, like a guy who actually boondocks and needs to keep his batteries alive. You don't need that.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
