time2roll
May 16, 2015Nomad
Big like group 27 or 8D or L16? You may have more battery than necessary.
If you want 3-stage charging including a low voltage float for reduced water use and maintenance... I recommend a PD4645 as it is designed as a direct replacement.
http://www.bestconverter.com/4600-series-Upgrade-Kits_c_133.html
With simple technical ability this should be an easy self install.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
