trailrider
Aug 22, 2016Explorer
Almot wrote:
The question was 160W vs 100W. Like it's been said - sort your needs out.
160W will harvest more than 100W, no matter what efficiency or mono vs poly.
If the goal is more energy, then buy more watts.
Out of two panels of the same wattage poly is better than mono.
If both are poly and if you use PWM, the one with higher Isc is better.
100W panel is pretty much auxiliary power, bordering trickle charger. 160W is only slightly more. To live reliably off solar for several days, you need at least 200-250W, even with .modest energy needs.
No the question was which is the better deal. My needs are sorted. I am going with 2 100 watt poly panels for starters.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
