96Bounder30E's avatar
96Bounder30E
Explorer II
Dec 05, 2013
Which LED bulb for a porch light?
One of the last remaining incandescent bulbs in my Bounder is the porch light.......Once of my concerns is, does the porch light need a waterproof bulb like what is in it now?(#105)....as most of the current crop of LED bulbs are an open design........or would a LED panel be OK?
If you have replaced your porch light bulb with an LED one......which one did you use?......I'm looking for warm white........
  • I use the same flat panel w/ 3 leds in it that I used in all the other fixtures.
    Its not the britest, but it don't need to be, and it don't hardly use any battery,....leave it on all nite.
  • I have used this replacement bulb for both the exterior porch lamp, as well as the bathroom light in our M/H. In the bathroom it works very well, but is not as bright as I would like for the porch.
  • Hi,
    I'd use one of the cobb style replacements. I had a flat panel--but snow got in--and even led's do produce heat--so the snow turned to water--and the led shut down.
  • 96Bounder30E wrote:
    does the porch light need a waterproof bulb like what is in it now?...or would a LED panel be OK?
    No. I use a 4x4 wafer for porch. It's not as bright as the incan, but it won't burn the plastic either.
  • My porch light used a 911 incandescent bulb. I replaced it with a 9 5050 LED cob style light. I wanted a low current light that I could leave on when I was out and come back after dark and see where the lock and steps were. It draws only 85ma. Not a big drain when off the grid.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
