Dakota98
Nov 17, 2014Explorer
mitch5252 wrote:
OP HERE. It's the Everest version of the Camp Chef stove.
I just went to Camp Chef's site and they showed this as an available bulk adapter, with the following description. Can I correctly assume the hose on the right will work with this stove (and the other appliances)?
Description
Need more propane than a one pound tank? This five foot Bulk Tank Hose Adapter will attach a bulk propane tank to a portable propane tank fitting. Perfect for attaching your Outdoor Camp Oven, MVP Sport Grill or any disposable bottle appliance to a bulk propane tank.
1/4" Hose 5' Long
Appliance End: 3/8" Female Flare
Inlet: Type 250 male quick connect
Max Pressure: 0.5 PSI
Thanks for your help.
PS: Red31, I have no idea what your post means...I THINK it has something to do with the things you use to screw on to the bulk tank? They turn in opposite directions?
Yes, that would be the best & easiest to use& it will work with the Everest. But, it can only be used for one appliance at a time, so you lose the advantage of the cylinders.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
