MrWizard
May 20, 2015Moderator
maroua wrote:
After reading a bit, I flipped a couple of breakers and it seems to go away when I turn off electric water heater breaker
If you are not on shore power, why would the wh be on electric from inverter sucking your batteries dry
Are you dry camping with the shore cord plugged into the inverter?
Then all appliances should be on manual and on propane
And if you are on shore power, the water heater should not be wired to the inverter anyway
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
