mobilefleet
Mar 05, 2015Explorer
usually 4-6 squarehead screw hold the inside trim panel, remove that and there should be 4 bolts inside there. The bolts are extra long and are all that hold in most units. Then you disconnect the white harness plug to the upper a/c assembly and it's ready to remove from the roof. This is for dometic units but coleman is prob similar. Doesn't matter if it's ducted. The ductwork isn't connected to the unit itself, it simply blows air through via the fan when it is running.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
