MrWizard
Jul 18, 2017Moderator
the micro-air won't make any difference in what can be run while the a/c is on
NOTHING with out the assisting inverter
the MA only assists the a/c in starting
it doesnot assist anything else
IF you install the multi plus , just unplug the fridge from the 120v outlet behind it
it will default to LP and stay there all the time
this is most efficient way to run an RV fridge any way
it really uses very LITTLE LP to operate
using the generator to make electricity for the RV fridge heating element is wasting 'fuel'
cool the fridge with LP
you won't have any switch over forgetfullness
