valhalla360
Aug 22, 2014Navigator
I suspect a lot of people talking about inverters didn't have one to start with. So if they want to use 120V/AC equipment, they need an inverter to change the 12V/DC to 120V/AC (or they might have had a small one and want to run bigger loads)
There is also the possibility you have a combination charger/inverter that charges your batteries when plugged in but also has an inverter built in for when you are not plugged in.
Regardless, if you actualy have an inverter, it is not neccessary to replace it.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
