DAS26miles's avatar
DAS26miles
Explorer II
Nov 30, 2017
Why are Solar Panels mounted to bottom instead of sides?
I have noticed on almost all solar panel RV mounts that they are designed to utilize bolt holes on the bottom rim of the panel. Is there a reason why they don't make it so you can bolt to sides and easily remove the panels for cleaning underneath or replacing the panel?
Note that drilling holes on the frame voids the warranty as I was told. But I'm still interested if it can be done.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
