MrWizard
Jul 02, 2017Moderator
Here is my routine
There are exceptions,
on the avg , I start the generator in the morning and run thru breakfast, maybe lunch
I run until charged, or charged to the point that solar can supply the needed power while also do charging
In the past year with daily full time use, the lowest morning charger on my meter was 69.x percent aka 30 percent overnight use
My last set lasted 5 years i expect this set to last longer
They are getting treated better, charged all the way to full, much more often
Since this set started out with an amp meter that counts the amp hours and displays the charge rate or discharge rate
The meter was added when the other set was several years old, until then it was watch the voltage, not amps and SOC
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
