Homeless_by_Cho
Jul 02, 2017Explorer
MrWizard wrote:
Here is my routine
There are exceptions, on the avg
I start the generator in the morning and run thru breakfast, maybe lunch
I run until charged, or charged to the point that solar can supply the needed power while also to charging...
I want to go to AGM batteries this fall and want to FULLY recharge them with solar ONLY everyday to get the best battery longevity.
I am very confused. Is that even a possibility? Assuming that I have enough solar panels and full bright sun, Is solar ONLY capable of producing enough voltage to quickly and FULLY recharge AGM batteries?
I keep reading about people bulk charging batteries using gen sets early in the morning and allowing solar to top off the batteries to 100% SOC thru out the remainder of the day. So again my mind still wanders if solar ONLY is capable of producing enough voltage to quickly recharge AGM batteries?
A very confused LeRoy
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
