C_Schomer
Sep 22, 2022Explorer
Deja vu… mine did that a few years ago. Suddenly no pumping and I’ll be dipped if I could find the problem at the CG with the general tools I had. It was the brass pex fitting at the pump inlet got a tiny crack in it. I got home and replaced it with a genuine plastic fitting and have not had any more problems. ANY tiny leak on the suction side will break the prime!
FWIW, I discovered an internal strainer at the water outlet of my water tank and I didn’t want to take a chance of that thing clogging up someday. I used a drill bit to get a hold of the strainer and it slid right out and then I put a strainer at the pump inlet. When I had my pumping problem I figured it was an air leak at that strainer but, hail no, it couldn’t be that simple.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
