fj12ryder's avatar
fj12ryder
Explorer III
Mar 16, 2017
Why do trailer brake shoes cost so much?
Another post that talked about his oddly cracked brake shoes got me thinking about maybe changing mine out this spring. After doing some checking I've discovered how expensive those darned things are!
We're talking around $28 per wheel for two(!) brake shoes, just for the lousy shoes. I can get the shoes for the rear of my truck for under $20 for both wheels. And there is at least twice as much material on the shoe too! Around $200 for my triple axle is outrageous. IMO anyway.
Oh well, whatcha gonna do.
  • j-d's avatar
    j-d
    Explorer II
    agesilaus wrote:
    Well here's a place selling Dexter parts, cheap. I don't know anything about them and beware of shipping costs: Trailer Parts Superstore
    I've bought boat trailer parts and a boat trailer disc brake setup from them. Also some RV parts. They are one of the few places that seems to know something about the stuff they sell. Actually went to inventory and pulled measurements on some parts I thought I could adapt to my boat trailer. So I can recommend them. You can subscribe to an email list, and they put full brake assemblies on sale fairly often.
    I learned from the boat trailer brakes that at least some disc trailer brakes use automotive pads, and that can make the replacement cost a lot lower than "marine trailer brakes." I don't know if the shoes for drum brakes are organized the same way.
  • time2roll wrote:
    Yes for the same reason I am going to install disk very soon.
    All my other vehicles are disk so the trailer may as well be same.
    Yeah, I'd like to have disks, but spending over $2000 to put disk brakes on a 7 year old trailer when it's original brakes still work is not very sensible. And I'm cheap. :)
  • Yes for the same reason I am going to install disk very soon.
  • They're off the Dexter 7,000 lb. axle with EZ Lube hub. A 12" by 2" brake assembly, I believe.
    Actually it's the idea that you can buy the whole assembly for not much more than the shoes cost that irks me too. And I hate drum brakes too. But I just can't cut loose with a couple thousand dollars for disc brakes. These work, but I hate working on drum brakes.
    And I do appreciate the advice and commiseration. :)
  • Tell us what size the shoes are. I have a source, maybe.
    Richard
  • Just buy the whole assembly new. I think there are three or four easy to remove bolts thru the backing plate that holds the whole thing on. Then You splice the electric wire and that's it, job done. I HATE working on drum brakes myself.
    Just one example from Amazon
    Make sure you get the right size and the right side. I bought them from a local RV place and didn't pay this much IIRC, may have been $35. Check Rock Auto, tho I'm not sure they carry RV parts or other online vendors.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
