dougrainer
Jun 01, 2019Nomad
You don't state brand, but usually over the years the bottom mount bracket shifts downward slightly and the top of the swing out arm is resting on the top bracket. The top bracket should be about 1/4 inch higher than the top arm mount. You should be able to move it back and forth with your hand and not scrape anything. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
