MEXICOWANDERER's avatar
Dec 28, 2017
Why Does Stainless Steel "Rust"?
I thought it weird. My knives rusted in the USA but they don't rust down here -- even in a salt air environment.
It ain't the chili...
Turns out the culprit is Chlorine.
Even as little chlorine as contained in tap water. Like any other chemical process, reaction is modified (accentuated) by heat and length of exposure time.
Chlorine tends to remove the protective coating stainless steel forms on it's finish. Chlorinated water is weak, but if it is heated and utensils spend time soaking in the sink, then this changes the scenario.
Ive got a few pricey 440c stainless knives that I would rather not have to deal with. So now I know. I avoid chlorine (my regular liquid dish-washing soap contains it). And I need not keep the blade smeared with cooking oil.
18-10 flatware is also sensitive to chlorine.
  • We have 30 year old utensils made with SS and no rust.
    Back in CA we had one of the best water (no profit) utility Co, but getting close to a year in Las Vegas where water is famous for being ugly, SS holds well.
  • Move to the country and pump water from your own well, and you won't have a chlorine problem.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
