Artum_Snowbird
Oct 22, 2013Explorer
6 volt golf batteries are designed to handle about 30-40 amps. You are trying to get 150 amps through both of them.
It's likely they will burn out inside or explode soon.
That's the biggest problem with 6 volt batteries, they are in series, so the current draw to handle a big load is passed through both batteries. With 12 volt batteries, each battery provides half the current draw because the batteries are in parallel instead of in series.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
