ktmrfs
Oct 22, 2013Explorer III
RJsfishin wrote:
Maybe if ya all would pay attention ??
The OP is saying, the new 1500 watt not only won't power his new 1000 watt range, it also won't power the small micro that the smaller 750 watt inverter powered w/o any trouble. Now what does that have to do w/ not enuff batteries, or anything else you can find fault w/ ?
Fact is, a decent 1500 watt inverter will power a good size microwave off 2 6 volt batteries, and thru 10 ft of 2 ga cable just fine. At least mine did for many years.
Well, the new inverter could have a higher cutoff voltage for the low voltage alarm.
His batteries could have been much further discharged than previous attempts with the 750W unit.
the cables with the new inverter could be inadequate for either case.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
