MrWizard
Aug 25, 2018Moderator
Class A, opps i thought the stated model was a trailer
it still all holds true
but as a test he could start the drive engine, and try the coffee maker in the inverter
if it worked , yahoo problem solved .. battery issue
then he work on upgrading the batteries
if NOT an early riser, use the generator
new RV with inverter should have a generator
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
